Having some trouble with the flx10. I would like to rewrite a code to turn off padfx when I use stem part fx when echoing out. Please see attached video!
My current code for the pad is:
var 'stemsnfx1' 1 ? 'stemsnfx 1': padfx "echo out" 80% 1 bt smart_pressed
Can someone help me write a code
var 'stemsnfx1' 1 ? 'stemsnfx 1': padfx "echo out" 80% 0.5bt smart_pressed
Please see attached video on reddit
https://www.reddit.com/r/virtualdj/s/W9C4AwjAUt
geposted Fri 27 Jun 25 @ 7:53 am
          Press the pad a 2nd time before calling stem_effects off seems like the simplest approach.
I think other work arounds [rewriting the script on the STEMS_VOCALS key] will give issues in edge cases.
geposted Fri 27 Jun 25 @ 10:13 am
