I have a MacBook Pro M2 Max with 32Gb RAM, running Ventura. I connect this to my Denon MCX8000 controller - hence Ventura as this is the last supported MacOS for this controller with the M-series CPU. It's run absolutely flawlessly until last night - the automatic update to the latest build caused huge issues - waveforms freezing for minutes at a time, usually when trying to browse directories or when loading a track onto another deck. At one point, all the gridlines for the active playing track disappeared completely! I did a gig last weekend with no issues - the only difference in the entire set-up is the VDJ build. Anyone else seen any issues on MacOS?
geposted 2 days ago @ 4:16 pm
Did you try rolling the build back to see if it goes back to normal?
geposted 2 days ago @ 4:22 pm
Rolled back but not had time today to get everything set-up - it's on the to-do list before next weekend's gigs.
geposted 2 days ago @ 7:51 pm
