Quick question, I’m using build 8350, and I have my sound effects running through my launchpad where they are set up on one page, the problem I’m having is that when I go to use a newer build it’s not saved or doesn’t transfer. Question is do I have to go into the newer build and set it up like the 8350 build or is there another way?
geposted yesterday @ 4:10 pm
