Topic: Can't pause or stop track
Yesterday I stumbled upon this issue: https://www.youtube.com/watch?v=-3xS_F2VjkM
I couldn't pause one of the tracks. The only thing that worked was to exit the program. I'm using a Numark Mixtrack Platinum FX. The version of the software is: v2025 b8645.
Has anyone else experienced this or knows the solution? I have made a couple of custom settings but not much really. Thanks in advacne!
geposted 7 days ago @ 10:01 am
I see the temporary Cue marker (white triangle in Scratch waveform) getting updated to current position each time you press CUE and reminds me the case where the touch-sensitive Jog is held.
Not sure if there is some trouble with your controller or any other controller or way you use to handle Jog, but next time it happens have a custom skin button mapped as touchwheel_touch and see if enabled. then click once to turn off.
The Deck is on Vinyl mode in your case though, so probably not the case, because it wouldnt allow the Track to play.
Still not sure.
Really curious if you can reproduce this.
@DJDAD
Thanks for the response! I'll try that and see if I can reproduce it.
The support team responded: Try testing with factory default map instead. If the issue is resolved then your custom map / edit is what is breaking the controller functionality
