I used to be tech savvy, but now I’m old. I’ve been using VDJ since Atomix days (so late 90’s? early 00’s?)
I have some gigs coming up and I figured I want the extra control of a DDJ (instead of just clicking a laptop)
What are some recommended DDJ consoles that work well with Virtual DJ? I don’t mind bias recommendations.
Also, all budgets considered.
Here are some bullet points of what I need:
I use 4 decks, so ideally a DDJ that makes use of 4 channels (either directly, or with easy selecting)
Fuss-free headphone routing.
Excellent reliability.
Clean, responsive, lag-free sliders and buttons (I have a Developmental disorder that makes me clumsy, so the last thing I need is slow/loose/stiff fidgety controls)
Manual access to eq pots, and eq filter.
I don’t need:
Scratching disks,
FX buttons or grids,
I don’t need:
Scratching disks,
geposted Wed 16 Jul 25 @ 7:14 pm
Surely the best thing to do would be to look at the Pioneer website to compare consoles and look at them to decide the features you need.
Personally I use the FLX10 and it's great.
geposted Wed 16 Jul 25 @ 7:16 pm
I mean, I could do that if Pioneer are decent?
Is it the general consensus that they’re good?
geposted Fri 18 Jul 25 @ 12:22 am
Oh wait a sec, I should clarify; I’m just using “DDJ “ as a catch-all for DJ controllers (of any make/model.)
geposted Fri 18 Jul 25 @ 12:24 am
Pioneer controllers are in general very well made and reliable, if you are from Ireland, here is a link to it and also the XDJ-AZ from a very helpful guy called John
https://www.iavdj.ie/product-page/pioneer-dj-ddj-flx10-4-channel-dj-controller
https://www.iavdj.ie/product-page/alpha-theta-xdj-az-dj-controller
geposted Sat 19 Jul 25 @ 10:43 am
That looks ideal. Thanks.
geposted Sat 09 Aug 25 @ 7:13 pm
