Topic: GeniusDJ problem
Hello
I have TIDAL subscription. I had setting in search radio button only TIDAL. etc
When i using geniusDJ, its shows only result from Deezer and IDJPool. When i load song - Dezeer login website is pop up .
When I click right mouse button and use look up i see result from Tidal too.
Normal searching (in searching bar) work correctly. Its shows only result from Tidal and Local files
geposted Wed 13 Aug 25 @ 7:25 am
hi,
Same issue, very annoying. Cant use geniusDJ because of this.
