HI. Sorry if this is in the wrong place. I use VDJ to broadcast to a Icecast server. I have another station that I want to broadcast to as well, but there is no way to simulcast in VDJ. Has anyone found a work around on how to broadcast to two Icecast servers at the same time?
I've tried several methods but none work. The closest I got was having VDJ play to a virtual audio cable, and then picking that up with SAM Broadcaster, but the meta data doesn't transfer so SAM doesn't show the song info being played.
Any advice?
Any advice?
geposted Wed 20 Aug 25 @ 10:57 pm
I figured it out. I can now use my deck with VDJ and stream to multiple servers. It was actually quite easy, the answer was sitting on my PC the whole time. I use BUTT to pick up the audio. It will stream to the server you set it to. The trick is so laughably simple. Run another instance of BUTT to pick up the same audio, but set it to another server. Set both (or 5) to pick up the tracklist.txt data so it sends the current song to the servers.
geposted Mon 01 Sep 25 @ 3:58 am
