Topic: Left ear PFL
How to set pfl to my left ear. It is my dominant ear. My master to my right ear.
geposted Tue 09 Sep 25 @ 7:41 pm
OPTIONS: Type headphones, go down to audio, splitheadphones, check yes
When I do it the pfl goes to the right ear
You could swap the channels in audio setup (so 4/3 instead of 3/4 for headphones for example)
Like this?
coldtoon wrote :
Like this?
Yeah it still ended up in my right ear
Can you not just turn your headphones round the wrong way? I have HD25s and they're universal so you can choose which side to use in which ear.
LOL that was my first thought when seeing the thread. It's taken 20 hours for someone to finally say it! :-)
headphones are not reversible
Why not? What headphones are they? Make and model?
OK well you didn't post make and model but clearly they're not DJ headphones.
I see the image says they're Razer Baracuda X wireless headphones - and the mic is removable.
I also use the quest 3 at times when dj'ing into vrchat
You can invert the channels with a jack -> rca and and rca -> jack adapters.
Or buy another headphone dedicated for DJing.
Like this
Just tried again, and swapping the channel numbers within audio config really works to swap channels though. You did press Apply after changing the numbers?
