Hey guys I have recently started using Virtual DJ with my DDJ SX2 and have noticed that the FX knobs do not seem to change anything or cause any notable impact. This is especially the case when it comes to FX like echo, delay etc.
There are a few exceptions to this case like when I am using distortion.
What am I doing wrong here ? Is there any setting that I have to change to make the effects more noticeable and if so, how do I change it ?
Please help and thank you so much for the help in advance :)
geposted Sat 13 Sep 25 @ 2:31 pm
If you're trying to hear the effect impact on your headphones with the volume channel down while "fx-processing" setting is set to "post fader" then that's normal and expected.
The dials still work, but they are just not audible on the headphones.
Instead they will become audible on the MASTER once you use them with the volume channels open
geposted Sat 13 Sep 25 @ 3:47 pm
I am not talking about audible in my headphones in this situation. They are not audible even in the master volume through the speakers.
I checked other posts and tried to increase the length etc, but I still could not feel any difference
geposted Sat 13 Sep 25 @ 4:01 pm
Have you read this ? https://www.virtualdj.com/manuals/hardware/pioneer/ddjsx2/layout/effects.html
Perhaps you're using the FX unit of the controller on "single" mode when you actually want to use "multi" ?
geposted Sat 13 Sep 25 @ 6:07 pm
I have the FX on multi mode already. That was a problem I had to figure out before :)
What I am trying to say is the FX that are assigned to the FX knobs is not noticeable when I use it. They don't make any noticeable or significant change while I am using it.
Is there any way to change/modify the intensity of the FX to make it more impactful ?
geposted Sun 14 Sep 25 @ 2:12 am
