For some reason, my recommended next section can no longer show any tracks that would work well with the current song playing. Its just empty. How can I get this back?
geposted Fri 19 Sep 25 @ 4:20 am
Did you delete your history files (or moved them away) ?
geposted Fri 19 Sep 25 @ 6:24 am
Thanks for the reply. I worked it out. It was me being impatient. I just created filter folder with conditions set to the bpm and key. Working alright so far :)
geposted Tue 23 Sep 25 @ 1:50 am
