Hi all - i use VDJ and want to get the rane one mk2. How do stems work on the mk2; vdj can breaks stems down into 5 seperate stems, but the mk2 seems like the pad and the new aux pad up top only support 4 (I assume thats how serato does it).
If we want to use the full 5 stem separation, do we have to use to mixer knobs? Which 4 individual stems does the pad and aux pad support?
geposted Sat 20 Sep 25 @ 2:20 am
As per the One MKII Manual the mixer sections is hardware operated, and even if you could switch the EQ knobs to Stems mode (See Nr.3 ), you still cant control 5 Stems.
The 8 Pads of the One MKII offer Full (5) Stems when the 5th primary mode is selected https://www.virtualdj.com/manuals/hardware/rane/onemkii/layout/pads.html
geposted Sat 20 Sep 25 @ 11:28 am
