Is there a way to assign a custom buttom that allows for the pitch reset to happen once pressed? I have tried a few ways and the closest it gets it it only working once i stop playing the other track. I want it to be playing a song at its original bpm at 125 for example, press play on a new track on deck 2 that has a bpm of 118, press the custom button and deck 1 lowers to 118 so deck 2 can then be brought in fully.
I am use the GT Vanced skin if that helps and noticed a button I can click that does it perfectly but it would be ideal if I could just press a pad on my controller to do the same thing.
geposted Tue 23 Sep 25 @ 2:08 am
pitch_reset
As simple as that.
But what you describe (original song at 125 BPM playing at 118 BPM in order to mix it) is actually the opposite: sync
As simple as that.
geposted Tue 23 Sep 25 @ 5:37 am
Ah yes! Thank you! :)
geposted Tue 23 Sep 25 @ 5:59 am
