Topic: Traktor X1 mk3 Z1mk2 screens issue
I've seen this reported before and wondering if there are any upcoming fixes? If you connect both the X1 mk3 and Z1 mk2 their screens are garbled and the led's on both flash randomly. I've tried it with the latest and early access releases of VDJ and it's the same issue. On their own they work absolutely fine. I've also verified they work fine with Traktor on the same machine with the same cable.
geposted Thu 25 Sep 25 @ 9:09 am
Is there any way of logging this issue, even as a low priority? I'd love for this to get fixed at some point so I can use these controllers together on VDJ.
I’m also seeing this issue too. Hoping for a fix as it’s great having a modular setup with working screens, and very distracting them flickering and showing garbage. Happens no matter how I connect them - direct to the laptop or not, with or without power. It seems to be they both claim the same MIDI port assignments.
I just did an event where I had to take my big controller with me. Hoping this issue can be fixed soon so I can use the modular Z1/X1 setup :)
Just an update not this, as I'm primarily a Mac user I didn't think of trying this on windows, but I tried it on on a windows machine with the latest VDJ version and the Z1mk2/Xmk3 combo works perfectly fine! So this must be a Mac specific thing then. Can someone confirm it works on their windows version too? At least we have an option now till it gets fixed on the Mac. Cheers :)
Any update on getting a fix for Mac?
The fix works perfectly! Thank you
