I know VDJ has auto gain, but is there any functionality like Traktors Ozone integration to have a compressor or constant loudness gain across tracks? Some of the stuff I play has quieter sections that aren't catered for using auto gain and having some sort of Ozone like compression would be welcome. Cheers
edit: can't seem to fix the typo in the subject line :(
geposted Thu 25 Sep 25 @ 10:03 am
Go here LINK and install either across the master output or on each deck, engaging it as required.
geposted Thu 25 Sep 25 @ 10:09 am
If your controller has "Master + Headphones" audio setup then you can purchase and download Ozone and use it as a VST effect on the master output of VirtualDJ.
Depending on how much processing you decide to do, the lag/latency could range from unnoticeable to unusable for DJ use.
That being said, running just a multiband compressor and a maximizer on Ozone to take care of dynamics, is absolutely doable with unnoticeable latency.
PS: Yes, I've done it.
PS2: No, I don't think it would be a good idea to have such an option natively on the software as compressors/maximizers are the most dangerous tool to use in order to destroy your sound while giving you the impression of improvement.
geposted Thu 25 Sep 25 @ 11:02 am
