Topic: Disable CTRL modifier?
My mappings are quite customized. (I use 1-8 and q-i for my cues, and I use CTRL to bring the crossfader back to the center) If I press CTRL while hitting one of my cues, instead of VDJ going to the cue, it moves the cue to wherever the playhead is.
Is there a way to disable this feature?
geposted Mon 20 Oct 25 @ 3:02 pm
Never mind, I was able to figure it out. :D
