Hi, something odd has happened. I'm looking for a song in VDJ, and cannot find it. It is in the folder where it should be. If I scroll through ALL of my songs I can find it, but it does not show up in a VDJ search.
I right-click on the song and an option to "Add to Database" is there, but I don't know how it was ever deleted from the database. Maybe something I did accidentally?
If I look in My Library>Not in Database, no songs are listed; however, if I start right-clicking on various songs, I can see other songs with the "Add to Database" option.
Is there to fix this without manually going through 5K songs to ensure they are all in the DB?
Not even sure how it got messed up. I've never had this issue before.
Thanks!
Thanks!
geposted Wed 22 Oct 25 @ 6:06 pm
To the right of the search box, there is a menu dot. Click the dot and make sure all the fields you want to search by are checked.
geposted Thu 23 Oct 25 @ 4:19 pm
