I’m using MK2 with Virtual DJ. When I slide the crossfader all the way to the right for deck 2, it stops playing just before being all the way to the right. I did the crossfader calibration and it showed successful, but the sounds stops at 125 out of 127. It works correctly with DJ Pro, however. Thanks!
geposted Tue 04 Nov 25 @ 3:10 am
What is the crossfader contour on the front panel of the unit set to? If it's set to fast (all to the right) then lower it.
geposted Tue 04 Nov 25 @ 12:10 pm
Which Rane MKII ?
Rane ONE MKII ?
In this case the crossfader is hardware, not software.
Rane ONE MKII ?
geposted Tue 04 Nov 25 @ 1:10 pm
is trhe rane one mkII a hardware mixer?
geposted Mon 17 Nov 25 @ 6:54 pm
@burnbad
Any audio config with deck1 && deck 2 is HW mixing.
geposted Mon 17 Nov 25 @ 7:01 pm
Thank you
geposted Wed 19 Nov 25 @ 3:47 am
