So a bug is found in CDJ export as follows:
If I use tag editor to update things for a local track in VDJ, and then re-export it by CDJ export, the change is not updated.
I added some characters for a trackname in VDJ, then did the export, clicked 'YES' since it found a playlist with the same name and asked me if it should write it over.
But the change is not written over.
geposted Sat 15 Nov 25 @ 2:05 pm
Any dev able to reproduce?
geposted Mon 17 Nov 25 @ 9:44 am
Please try if fixed in EA build 8890
geposted Wed 19 Nov 25 @ 2:25 pm
Great Adion! Seems to work.
I had to check "keep sync'ed"
geposted Thu 20 Nov 25 @ 4:54 pm
