Hello, I have an FLX10 and I use the padfx to remove vocals with the “echo out” effect, but when I activate the three stem FX buttons (INST - VOCAL - DRUMS), the padfx does not work properly. While the stem FX are deactivated, the padfx works, but when I activate them, it stops working. The vocals suddenly cut out and the other stems sound terrible.
Can you please fix this? Thanks
geposted Sun 23 Nov 25 @ 6:07 am
Will be fixed in the next update
geposted Sun 23 Nov 25 @ 6:36 am
