Topic: Disable keylock (master tempo) while nudging
Hi, I have issues with all of the values for the "pitchQuality" setting regarding nudging.
With all values except for "1", many of my tracks become audibly quiter and reduced in quality while the sound algorithm maintains the key, (masterTempo is turned off!).
With pitchQuality = "1" I can hear that it just repeats (slowing down) or skips (speeding up) the samples in the audio, which also doesn't sound great.
I wish to use the same approach of just stretching the wave as needed, i.e. the pitch changes just like when using the pitch fader with keylock / master tempo disabled.
How can I configure this?
geposted Tue 25 Nov 25 @ 9:06 pm
If you don't want any master tempo at all, even when bending, you can set pitchQuality to -1
I don't get any change in volume while pitch bend with pitchQuality at 2, 3 or 4 though
Thanks a ton, that's exactly what I was looking for.
Where is this documented?
I don't think it is, although it was probably mentioned on the forum before.
I think most people are also much more sensitive to the pitch change caused by bending without master tempo, compared to the changes caused by master tempo.
