Does anyone know if there is a way to extend the capability of my setup, I have a denon mc6000mk2 which doesn't have any trigger pads, i also own an akai mpc drum pad usb. Is there a way i can connect both at the same time to VDJ and map say the stems to the drum pad whilst continuing to use the controller at the same time?
I'm on a macbook pro.
geposted Tue 02 Dec 25 @ 3:01 pm
Which Akai MPC model exactly ?
geposted Tue 02 Dec 25 @ 3:41 pm
My mistake, akai lpd8
I also have an mpk mini too
geposted Wed 03 Dec 25 @ 12:40 am
lpd8 is supported hardware.
geposted Wed 03 Dec 25 @ 1:12 am
Can you use it in tandem with another controller?
In my case a demon mc6000 mk2
geposted Sun 07 Dec 25 @ 9:40 am
of course.
geposted Sun 07 Dec 25 @ 11:20 am
So i could plug them both in then map the akai pads to the stems for example?
geposted Sun 07 Dec 25 @ 3:23 pm
