When setting a loop with turntables reloop 8000 mk2 and pioneer DJM S 11. I have the loop button on. When I hit the right end point of loop button to use the turntable vinyl to pull back the loop, the track starts playing. If there was a way to post a video, I would.
geposted Fri 12 Dec 25 @ 12:52 am
If you have a publicly accessible video on youtube, you can post it with the youtube tag here.
Otherwise, you can host it on your cloud storage provider of choice and post the link to it here.
geposted Fri 12 Dec 25 @ 12:44 pm
Here's a video of the issue. Trying to set the loop end of the loop. Enable the loop end function, then pull back the right jog and it starts playing, making setting the end point impossible.
https://youtu.be/8Nlwvfs0O4o
geposted Fri 12 Dec 25 @ 2:26 pm
Loop In/Out fine-adjust functionality is not implemented in DVS.
geposted Fri 12 Dec 25 @ 2:34 pm
So there's no way to set the end point. That stinks. But I guess I'm the only one that uses loops it seems based on trying to find videos out on the internet. But works fine with controllers. Anyhow thanks
geposted Sun 14 Dec 25 @ 12:11 pm
Does it not work using the in/out adjustment buttons on the skin (when using DVS)?
geposted Sun 14 Dec 25 @ 2:27 pm
Had a loop lamp light up Saturday Night, thought I was going nuts, this is a new one on me , I know it's not a Reloop controller.
VDJ 2026 with DDJ800 🤔
geposted Tue 16 Dec 25 @ 11:08 am
