hi not sure why but i am getting this about my Pro license ?
VIRTUALDJ
You already have a VDJ PRO Infinity license
so why am i not getting the new up 2026 updates i have updated my software
any help please
thanks in advance
VIRTUALDJ
any help please
thanks in advance
geposted Fri 12 Dec 25 @ 1:45 am
VDJ has only been released in "Early Access".
to get the Early Access update: go to OPTIONS > earlyAccessUpdates > Yes
then restart VDJ, you should then get the 2026 update.
Note: A Pro Infnity license is not required to get to get early access.
(just need to change your preference in OPTIONS)
geposted Fri 12 Dec 25 @ 5:12 am
hi thanks for your reply i have done that & i dont get the new features
just makes no sense only have the license on 2 laptops i just wanted too check out the stuff on my home laptop to get used too it
geposted Fri 12 Dec 25 @ 7:48 am
That is strange, its not difficult to get the early access build.
What is your current build of VDJ? maybe you have 2026 already
At the time of typing this reply
Early Access (EA) is 8950 . . (which is VDJ 2026)
and the standard release is 8909.
geposted Sat 13 Dec 25 @ 4:17 am
You can find the link on this page:
https://www.virtualdj.com/forums/266309/General_Discussion/%5BNEWS%5D_VirtualDJ_2026.html
geposted Sat 13 Dec 25 @ 8:54 am
