I have Beatsource and Deezer for my streaming services atm and was wondering why when i do a search for a song does only one service shows up with listings. Why don't both Deezer and Beatsource show up? And yes they are both logged in, have the song, and are both checked in the online catalog options. Thanks!
geposted Thu 18 Dec 25 @ 1:50 pm
You have either the deezer or beatsource folder open perhaps?
geposted Thu 18 Dec 25 @ 2:38 pm
What do you mean? how would it be either or, or both? Is there an option to select that? I would like both to show up. Thanks.
geposted Thu 18 Dec 25 @ 3:01 pm
I mean if you have it selected as the current open folder.
geposted Thu 18 Dec 25 @ 5:29 pm
No, whatever folder or list i am on at the time I just type in the search bar for the song. Do I have to go into each folder? I was under the impression that VDJ would check everywhere no matter where I am in the browser when i type the song in the search bar.
geposted Thu 18 Dec 25 @ 7:19 pm
If you have a specific online music folder selected, then it will search just that service, but otherwise it should indeed search all the services you have checked in the search options.
You could open the folder to see if there was any problem logging in perhaps though
geposted Thu 18 Dec 25 @ 7:25 pm
