The sampler for my custom samples only works on the deck I'm playing on. They used to work independent from the deck A&B. The samples that come with Virtual DJ works fine on either side. this is very frustrating and annoying. You guys keep adding features nobody asked for and changing things that worked good with every update. No instant doubles are another thing I don't understand. If the program is supposed to reflect a real vinyl experience, why don't you add this feature to accommodate
people who want to simulate dj'ing with vinyl?
geposted Thu 18 Dec 25 @ 4:14 pm
If you want to create a regular sample bank, switch off StemSwap in the context menu for the bank (by the way, this has been a feature or more than a year so not sure why the complaint is happening now).
Instant doubles exists - it's called "Clone from deck" and is normally on all controller mappings where it's expected (double tap the load button normally), and can be executed from a custom button/keyboard shortcut using the clone_from_deck verb (also in the Scripting Wiki). I use it all the time with DVS, and the DVS system works very well (since you asked about emulating Vinyl).
Also, take a look at the VirtualDJ User Manual for tthe Sampler to learn more about how it works in VirtualDJ.
The remaining rant is both unnecessary and untrue - many people appreciate the features being added, if you don't like it, then don't use it/switch it off (there is always a way to do it if you read the manual/ask questions here about it).
If you have a feature you want considered, go to the Wishes & New Features forum, check if the request is already there and add a comment with your views to it, if not, make a new post with the request.
You are clearly not a new user, so you should know how things work on the forum/know how to go about finding information - ranting is not the way to do that.
geposted Thu 18 Dec 25 @ 5:12 pm
