Topic: Karaoke and Lyrics outputting to master
Karaoke and lyrics are outputting to master feed even if the crossover is locked to the other deck. So while I que up a track, the karaoke and lyrics are outputting to the audience.
geposted Sat 20 Dec 25 @ 3:30 am
Displaying Lyrics & Karaoke is similar to Video mixing.
https://www.virtualdj.com/wiki/VideoMixing.html
If you are using the crossfader to mix your Decks, perhaps the Video Crossfader is "un-linked" to the audio Crossfader or some other case that is mentioned in the Guide above
So you are not seeing the same issue it seems. I have been video mixing for a long long time now, my crossover is linked. This is only happening when the new feature (karaoke, lyrics) is selected. Please test on your end. Have video or lyrics on, keep the crossover to the left, play a track on the right deck, the lyrics will show up on the screen. Soon as you hit play on the left deck, the lyrics from the right goes away but if you stop the track it reappears.
