Topic: Recommend Next
I have noticed recently that the Recommend Next is not working properly. Most of the time it stays blank when it used to always fill with recommendations regularly. The Similar is working fine. Are there some settings that may have changed? Is this a known issue? I am using VDJ on a Windows machine.
geposted Sat 20 Dec 25 @ 8:57 pm
I'm reproducing the issue (tested with latest v2026 b8985)
(btw, if dev teams read us: could you make the build version selectable/copiable in settings?)
Should be fixed in 9004
