So I use the broadcaster video skin and one of the options is to have the title of the track that’s playing, shown. That’s good and that what I want.
When I use vinyl in thru mode, it shows Timecode input 1/2 .
Is there anyway I can replace that with something else or is this hardcoded in??
geposted Wed 24 Dec 25 @ 1:15 am
Only by editing the skin (The timecode thing is hardcoded)
You can edit the skin so that when deck X is using timecode to not show "Artist - Title" on screen..
geposted Wed 24 Dec 25 @ 5:54 am
Could you help me with that?? Im not sure what Im supposed to look for??
geposted Wed 24 Dec 25 @ 2:46 pm
It would be something like
get_artist_title or something similar
and you want to change it to a query, something like
That's the rough outline without opening the skin and giving an exact answer.
get_artist_title & param_contains "timecode" ? get_text "The thing you want to replace with" : get_artist_title
geposted Wed 24 Dec 25 @ 4:53 pm
Ok aewsome!! Ill take a look, Thank you fellas!!
So I can only find 1 "get title/get artist" and when I try to open VDJ video, it gives me an error at the line I added your script to.
geposted Wed 24 Dec 25 @ 5:16 pm
If you mean one of Rune's skins, there are six versions. Which one exactly?
geposted Wed 24 Dec 25 @ 6:12 pm
Lol! I forgot he's has a few, I'm using the 'Boilerplate'
geposted Wed 24 Dec 25 @ 6:21 pm
Looks like this is the bit where it all happens -> lines 276-294
It's checking (via visibility) for audio on the master, which presumably is always going to be the case, so I guess it needs to check for timecode active or not instead.
Not active = show track info. Active = show something else.
visible="not get_hastimecode" for track info and visible="get_hastimecode" for no track info (would be my guess)
<panel visibility="deck master is_audible">
<textzone group="horizontal" deck="playing" align="center" scroll="yes" visibility="0.7">
<pos x="+5" y="+0"/>
<size width="1920-74-74-10" height="60"/>
<text fontsize="24" color="text" weight="" action="get_artist"/>
<text fontsize="24" color="text" weight="" text=" - "/>
<text fontsize="24" color="text" weight="" action="get_title_before_remix"/>
<text fontsize="24" color="text" weight="" action="get_remix_after_title"/>
</textzone>
</panel>
<panel visibility="not deck master is_audible">
<text fontsize="24" color="text" weight="" text="♩ ♪"/>
<text fontsize="24" color="text" weight="" text=" "/>
<text fontsize="24" color="text" weight="" text="♫ ♬"/>
</textzone>
</panel>
geposted Wed 24 Dec 25 @ 6:54 pm
Yeah, that's the area I was messing with, just couldn't figure it out unfortunately.
geposted Wed 24 Dec 25 @ 10:03 pm
Well I’ve tried a few different scripts and I always end up with an error lol!
geposted Fri 26 Dec 25 @ 9:46 pm
I'll pull it up.
Guessing you're using the deviation with the Album Art added , that we did a year or 2 back?
file in pm
file in pm
geposted Fri 26 Dec 25 @ 10:08 pm
geposted Fri 26 Dec 25 @ 10:21 pm
