Topic: Weird question about headsets..
Hi there, my husband uses Virtual DJ and suggested I ask here about a weird headset question. I've looked all over, but it doesn't seem to be a significant issue. The problem is that my head is relatively small and I have very straight, slippery hair, so most headsets slip off, get banged up, and I keep breaking them. Do you have any suggestions for a non-slip headband or a DIY way to address this issue? Thanks for any help!
geposted 3 hours ago
My advice would be....................don't wear headphones!
For some time now I've been using IEMs (in ear monitors) which is what musicians use on stage these days.
KZ ZS10 from Amazon (you can get them with a built in mic too, if you're referring to gaming).
