When will the "Title" Plug In be available in 2026 update. Can't update until it is available.
geposted Thu 08 Jan 26 @ 8:12 pm
It's available as early access now but title plugin was never missing just difficult to get to with the new effect_list feature
call
deck master effect_show_gui title
call
geposted Thu 08 Jan 26 @ 8:31 pm
Hi, are you saying it is in 2026, if yes how do i turn it on or activate it. It was in the Video FX pull down menu with other effects such as "Text" and "Screen Grab". It does not show up in the 2026 version
geposted Tue 13 Jan 26 @ 5:07 pm
Are you running the latest build? Check extensions/effects/video fx/ to see if it's installed.
geposted Tue 13 Jan 26 @ 5:17 pm
I did that after I updated and it wasn't listed. Talked to tech support and they agreed with me and said it would be added soon. As a result I had to revert back to the last 2025 build. I don't want to keep updating and then revert back again to 2025 over and over just want ted to see if has been updated in the new 2026.
geposted Wed 14 Jan 26 @ 3:00 pm
Install the latest build and (if necessary) reinstall Title from the extensions page.
geposted Wed 14 Jan 26 @ 3:21 pm
No need to re-install anything, just update to the latest Build.
Build 9004 - current Public Build - should offer Title Plugin to Install from Extensions...
geposted Wed 14 Jan 26 @ 3:36 pm
