Hi all!
On my FLX4, two rotaries are not picked up by the skins on startup. The MASTER and MIC Levels. The MASTER can be annoying if the level is low on the controller, but I am using audio directly from the laptop through USB. If I'm not careful, I then get a 100% blast since master_volume is 100% on startup in VDJ. If I just touch the button, the value is read correctly and master_volume will be set according to the pot value. Can this be done automatically on startup, either in the skin or the mapping file?
Thanks!
Thanks!
geposted 5 hours ago
