Topic: Gemini Ctrl Six does not automatically connect
I got a Gemini ctrl six controller secondhand. Since I knew it came with VirtualDJ LE 6/7, I thought it would work on the free version. My controller is not automatically detected. I search "Missing controller" on the setting screen, and I can search for my controller. But when I double click it, it shows a menu and the controller still doesn't work. Auto detection works on a modern Pioneer controller.
Is the Gemini ctrl six compatible with the VirtualDJ Free? If not, what is the minimum version I need? I know you can't get LE 7 anymore, so how to I make sure that my controller will work with the paid version?
geposted 7 hours ago
