hi. I run a licensed product and have a 2009 MacBook with VMS 5 and runs with no issues. using a 2018 or 2024 MacBook purchased to upgrade from 2009 model, vdj has just starting to stall or jumps back and forth like you are scratching. when it stalls on auto play it will highlight the last track it played in the list but shows on the deck the first track in the list of tracks to play and this can be 10 or 50mins into a session. this started with what can only be compared to a hiccup and has now get to this. I connect via the usb with external ps for the controller. it did start whilst using the vms skin but that works on the 2009 Mac and has just got worse. I have tried various versions. Any help would be gratefully received. thanks in advance
geposted Mon 26 Jan 26 @ 10:36 pm
Update! Reformatted both the 2018 Mac Pro and 2024 Mac Pro and reloaded the vdj and connected the vms5 controller but declined the vms skin. Bingo no longer any issues. I thought it was a glitch in the software and doing this confirmed it. Now plays faultlessly. Thanks for taking the time to read👍
geposted Wed 11 Feb 26 @ 9:30 pm
