I have a question. Can the Automix function play on two decks? Because I noticed that it always works on one deck. Thank you in advance for the information.
geposted 3 hours ago
Yes there's a setting for dual deck automix however it's a deprecated feature and it's better using the single deck instance.
Could you describe how to do this? Thanks in advance.
Go to settings and search for dual.
