Topic: Mixtour Pro pads & custom pad mode
Hi everyone,
I recently acquired a Mixtour Pro to complement my LC6000s and make my mobile setup easier.
I intend to use the Mixtour Pro's pads primarily for the stem FX function (pads 4 through 8 in Pad Stems + FX mode).
I'd like to activate split mode so that only pads 4 through 8 for each deck are visible in this pad mode, instead of pads 1 through 4.
Furthermore, I'd like the pads to blink when the corresponding stem FX is active.
I've tried a few scripts directly in a custom pad mode. The best workaround I've found is to create a custom pad mode where I copy the stem FX actions to pads 1 through 4, but I can't get the pads to blink when the effect is active.
Any ideas?
geposted 6 hours ago
