Separating all my tunes into publishing labels using the virtual folders feature. A lot of the labels either have parent, or sub-labels.
An initial idea I had was to put sub-labels into the parent labels on the tree on the left hand side of the browser.
Then it occurred to me if I was after a specific label that was a sub label I'd have to open up the whole tree to find it, as the parent labels on the tree would be in alphabetical order - I'm talking about a thousand labels here.
So then I had the idea of a comment on a virtual folder (e.g. sub-label to XXXX) but there is definitely no option to do this.
I thought this would be a common request and wonder if the coders thought that adding a comment to a folder as well as a track may confuse things?
Not the end of the world, but there's no way I'm messing with my tags!
geposted Tue 10 Feb 26 @ 10:08 am
Why not just use the search_folder
geposted Tue 10 Feb 26 @ 10:18 am
Bam! I’ve been using VDJ for 18 years but never noticed this feature!
That’ll help immensely, although I may put a request on the appropriate thread to be able to add a comment on a virtual folder.
Thanks so much.
geposted Thu 12 Feb 26 @ 4:35 am
