Forum: VirtualDJ Skins
Topic: cant edit skin xml
if i open a copy of the original pro.xml i only see:
NUL NUL NUL NUL...
I also try to install XML Tool for Notepad ++
I can open the xml from DennYo to edit it.
geposted Sat 14 Feb 26 @ 5:41 pm
You were wanting to work on controller2020 right? when you open in np++ what encoding does it say it is bottom bar right side [should say utf-8]
i have an changed original pro skin.
But i cant edit the original file.
Last time was last year.
Notepad open it in ANSI, after change with coding to utf-8 or convert to utf-8 only the NUL... will dont shows and no lines are there.
I also try another tool and get an error.
There is onyl this default folder in my skin folder.
On the right window is the opened dennyo skin with utf-8.
So i think i have to repair my skin.
https://limewire.com/d/bc3Vf#4c0td8dLSP
It seems i found the missing link,
All old zip files and skins are corrupt, maybe after copy to new pc.
I cant find my changes in the skin so vdj load an other backup skin in background, not from the skin folder.
Now i zip all and delete the folder and install latest vdj version, then the default folder is missed,
also i go to edit in vdj and there is the missing folder and i can edit the skins.
