Topic: Problem with EQ/Stems after latest update
Hello, not sure if this is the exact location to put this but after the update yesterday, i've noticed at various times when using the Modern EQ the EQ with just go in and out intermittently. Did a 6 hour set up Twitch last night and at the most random times, it would on it's on just toggle back and forth from "MEL/VOX" to "MID" mid mix. i've had this happen using both the knobs as well as the Stems 2.0 pads. So let's say a song is playing, I press the "Acapella" pad and the music drops (like it is supposed to) but then the music will just come back in and out and in and out without me pressing anything. I played around a bit tonight and the same thing happened. it's definitely not constant but when it happens it a lotta frustrating. Not sure if this is a known deal or not.
Build v2026 b9171
MSI Titan DT 10SGS
Edition Windows 11 Pro
Version 23H2
Installed on ‎10/‎6/‎2025
OS build 22631.6199
Experience Windows Feature Experience Pack 1000.22700.1108.0
64 GB RAM
i9-10900K CPU
RTX 2080 Super
geposted 12 hours ago
I notice that too, after playing for about an hour the stem pads would work intermittently.
I have a Rane Four controller
Build v2026 b9171
MSI Titan DT 10SGS
Version 23H2
OS build 22631.6199
64 GB RAM
i9-10900K CPU
RTX 2080 Super
I'm glad to hear that it's not just me :)
