In the current Early Access version b9171, there appears to be a small but rather nasty bug in conjunction with the Prime 4+.
Everything works normally on the first launch. However, if you close VirtualDJ, it seems that HID mode is not exited correctly. If you then restart VirtualDJ, the program freezes completely.
Neither ending it via the Task Manager nor killing individual processes helps – only a complete restart of Windows 11 resolves the issue.
This behavior has clearly only occurred since the Early Access build b9171.
Regards, Uwe
Regards, Uwe
geposted 7 hours ago
