hi . (Title should be DDJ-800 not CDJ-800)
I notice about a month pass, that the Pad Page is no longer changing based on the controller selection, and opposite is true when changing in VDJ to the controller.
Every other item is control fine, but when first starting the software, the master volumn blink to appear and disappear for a few seconds. Like appear, disappear, etc.
forgive me not sure how to explain exact wording.
When I look in Controller Activity it blink : ONEXIT ONINIT
geposted 2 hours ago
Pad pages ? Hmm perhaps u mean DDJ-800 not CDJ.
Try the "factory default" Mapping in case you use some custom one and see if you now control those.
This indicates that the controller is briefly disconnected and reconnected.
First thing i would do, would be to change USB port and/or USB cable
memusic.jp wrote :
...When I look in Controller Activity it blink : ONEXIT ONINIT
you are correct. forgive me typo .
I try to replace USB port, no change.
I try to go to factory setting, no change.
I order new cable for test and will reply of result.
Thank you
