I personally have very little experience with VirtualDJ - asking this on behalf of my father who uses virtual dj for gigs but is not the most technically inclined. From what he tells me the song list display used to be a detailed list with no album art shown. It appears after one of the recent updates it added album art to the lists. We were able to remove the art from the list but it appears to have stretched each row out larger than is preferred and that spacing doesn't change regardless of whether the album art is there or not. Is there a way to revert it back to what he was using previously? Spent about an hour trying to no avail. I found the link to download previous versions of virtualDJ, but, looking through the patch notes, it is unclear when this may have changed (which version).
geposted 4 hours ago
Best to check the amazingly detailed VDJ Manual. (especially the sections for the Browser)
Here is link on how to change from Grid view to Detailed view (from the Browsers Options menu dot).
https://www.virtualdj.com/manuals/virtualdj/interface/browser/toolbar.html
Browsers Options menu dot > Display Options > Display List as > List view
Which may be your question.
If you are in Detailed view.
All columns widths, can easily be adjusted, by moving your cursor to a division of the column label, and dragging, left or right.
geposted 2 hours ago
