Topic: Cue 3 disabled?
Hi, I'm experiencing a strange issue with hot cue slot 3 specifically.
Cue 3 seems to be disabled across every track I load, while all other cue slots (1-2, 4-8) display normally in red and function correctly. When I press Cue 3 it does nothing. I tried deleting the cue point from slot 3, but I'm unable to set a new one — clicking to assign a new cue in that slot doesn't work at all.
There seem to be no issues with using slot 3 on other pad modes like beatjump. This happens on every track regardless of which skin I use. Has anyone seen this before or know what might be causing it?
geposted 6 hours ago
check the pad page editor for hotcues, sounds like you changed the script there.
