Is it possible to activate this for the Sampler Banks,
Yesterday i try some kick, hihat and Roll loops and everyone have another Volume in the record.
I want to use Stems to.cut the original Kicks and then Play different kick Sampler in a Club Set.
geposted Wed 04 Mar 26 @ 6:04 am
You can increase the gain for each sample, if you see it's low. You can also apply a compressor or maximizer plugin on the sampler output (I use LoudMax).
If you're using StemSwap though, you'll have to enable FX on the rhythm and load the effect in a deck slot.
geposted Wed 04 Mar 26 @ 9:32 am
I use the Sampler Banks with a NI F1 next to my prime4.
I know the FX for the Sampler.
But my question IS If the a Option to Bring the Sampler everytime to the Same max gain Like the playing Song.
Then i can use the Volume Fader of the Sampler Deck to fade in and Out.
But its very tricky to prepare the gain of each Sample to the Zero gain of Most Tracks.
Actualy i give the Sampler more gain, then i reduce the Sampler Main Volume and Later i can reduce also the bank Volume.
But its never the Same Volume Like in the Song and a Lot of Work and Hearing.
geposted Wed 04 Mar 26 @ 9:58 am
I know what you're asking. That's why I gave you a solution. My personal method is to use LoudMax.
I was doing exactly the same a few days ago, mixing new drums (a loop) with an old song, replacing the original drums.
To be 100% clear - there's no autogain on the sampler.
geposted Wed 04 Mar 26 @ 10:40 am
I know loudmax,
Then i have to Set IT to master as Oninit,
Else i will forgot to start in the Club.
At the Sampler i have tree Main FX i use to Change this Sound of it.
Today i will try to record some Tracks only the Stem Kicks, then i Play with the gain of the Sampler Till is nearly the Same.
geposted Wed 04 Mar 26 @ 12:40 pm
No you don't have to set IT 🤣 to master. Obviously if you do, it won't just affect the sampler output (which is where the issue lies).
On my default setup, I have LoudMax on the sampler auto-enabled when my system starts up - and a custom button that shows green to confirm it's enabled. I do this specifically for the reasons you mention, to ensure that the samples play back a) loud enough and b) at an even level.
geposted Wed 04 Mar 26 @ 12:50 pm
Okay, i have to Check how i can Autostart loudmax at the Sampler.
geposted Wed 04 Mar 26 @ 1:39 pm
I try this with oninit from the sampler controller:
But this doesnt start the FX on Plug in.
ONINIT=
set '$sampbrw' 1 & effect_active "LoudMaxLite64" 'sampler' on
geposted Wed 04 Mar 26 @ 5:24 pm
Can u help me, how can i activate a specific fx like echo for the sampler deck?
Dont work.
Also i want to get a led light on, when this fx is activated on the controller?
Like:
But its also, dont works.
effect_active 'sampler' "Cyclone"
Dont work.
Like:
effect_active 'Cyclone' ? on : off
geposted Wed 04 Mar 26 @ 7:08 pm
