I’m sure it will happen in the future but I hope the lyrics size changes.
I think VDJ needs to make the overall interface easier to read and navigate.
Too much is going on and unnecessary things on the main screen
More things need to be hidden when not needed after being changed or edited.
When DJing I just need to see a bigger jog wheel and time stamp
Good clean Wazeform and lyrics size
geposted Wed 04 Mar 26 @ 3:32 pm
If you want you can change skins for better experience, example "Starter" layout
geposted Wed 04 Mar 26 @ 5:14 pm
Yea they need to build off the starter skin
My main thing is text size to be visible from a standing view while DJing
The screen and software revolves too much around people the mix and DJ from the laptop with no controller.
I love the software but the clutter is too much. Even with the wave lyrics.
I love the feature but the text is so small
But I patients. I know the software will upgrade eventually
geposted Wed 04 Mar 26 @ 5:45 pm
Try third party skins (Vanced GT has excellent spacing and larger font support and @PhantomDeejay's GTS 2025 is also well scaled and packed full of features).
geposted Wed 04 Mar 26 @ 7:20 pm
You can edit the skin and change the font size of the text at the waveform.
Go to edit skin in vdj, make a backup of the original file and search with e.g. notepad++ for:
It look like this:
Now look for:
And change the fontsize, then save the file and restart vdj.
Else you can build a skin, like u want with the skin editor. Be free.
<scratchwave
It look like this:
<scratchwave deck="1" orientation="horizontal" color="scratch1" color2="scratch2">
<pos x="0" y="+45+12"/>
<size width="1920" height="43-24"/>
<grid size="1" mainsize="4" height="8" pos="-10" maincolor="deckcolor" color="darkgray" mirrored="true" shapepos="-12" shapemirrored="down"/>
<gridlines width="1" color="darkgray" transparency="0.5"/>
<cue y="-12" height="15">
<mask x="307" y="0" width="15" height="15"/>
<text dx="+12" dy="-2" weight="" fontsize="15" color="textdarker"/>
</cue>
<overlay>
<pos x="960" y="-12"/>
<size width="1" height="43" />
<background color="needle" shape="square" />
</overlay>
</scratchwave>
Now look for:
geposted Thu 05 Mar 26 @ 7:23 am
Why not help him with that, and send him the skin ;)
All are not that comfy to do things like that..
geposted Wed 11 Mar 26 @ 5:39 pm
It's part of the latest (second) early access release:
When set to 3.0 as an example:
geposted Thu 12 Mar 26 @ 11:06 am
NICE, thanks a lot
looking forward to the next public release
geposted Thu 12 Mar 26 @ 2:58 pm
Becouse that is not the one thing of customizing.
My skin is my best choice, the next body cant work with it.
So its the best way to customiz itself like he want.
Becouse i dont know what is the best size he want and so on.
geposted Thu 19 Mar 26 @ 7:11 am
