Is VDJ supporting the iRig Blueboard bluetooth-controller?
geposted 5 hours ago
https://g1.ikmultimedia.com/html/Manuals/iRigBlueBoard/iRig-BlueBoard_User_Manual.pdf
Not a lot to it, this is very much in the realm of user definable gear,
iRig-BlueBoard_User_Manual wrote :
MIDI over Bluetooth mode 1
1. Push and hold the “B” button and then switch ON the device. This way the BlueBoard will start up in MIDI
over Bluetooth mode 1. After this the Status LED will start flashing blue.
2. From the app, follow the procedure to connect to iRig BlueBoard. Once the connection is successful, the
iRig BlueBoard status led will light up steady blue.
These are the specifications for the MIDI over Bluetooth mode 1:
Transmit Channel: 1 / Receive Channel: 1
Transmitting:
Switch A: note C3, velocity 100, momentary action
Switch B: note D3, velocity 100, momentary action
Switch C: note E3, velocity 100, momentary action
Switch D: note F3, velocity 100, momentary action
A “Note ON” message is send when the button is pressed, and a “Note OFF” message is send when the foot-
switch is released.
Exp Pedal 1: CC#12.
Exp Pedal 2: CC#13.
Receiving:
Led A: note C3, momentary action
Led B: note D3, momentary action
Led C: note E3, momentary action
Led D: note F3, momentary action
These are the specifications for the MIDI over Bluetooth mode 2:
Transmitting:
Switch A: CC#20, momentary operation
Switch B: CC#21, momentary operation
Switch C: CC#22, momentary operation
Switch D: CC#23, momentary operation
Value 127 is sent when the foot switch is pressed, and value 0 is sent when foot switch is released.
Exp Pedal 1: CC#12, continuous.
Exp Pedal 2: CC#13, continuous.
Receiving:
Led A: CC#20.
Led B: CC#21.
Led B: CC#22.
Led C: CC#23.
Received values higher or equal than 64 will turn the footswitches LEDs ON, values lower than 64 will turn the
footswitches LEDs OFF.
Transmitting:
switch is released.
Exp Pedal 1: CC#12.
Exp Pedal 2: CC#13.
Receiving:
Transmitting:
Receiving:
Led A: CC#20.
Led B: CC#21.
Led B: CC#22.
Led C: CC#23.
OK, thank You Locodoc for the quick help.
Just shot it for half price and will give it a go.
Best wishes
Best wishes
geposted 4 hours ago
