Topic: How to map a specific control ?
Hi there !
I am trying to map the "Transparency" dial in that "Visuals" menu to a knob on an external controller. Tried the tooltips but cannot find its ID to map it. Anyone can help ?
In the same vein, is there a way to figure out all controls / buttons / faders names in the entire VDJ GUI, so it would be easier to custom map to an external controller ? The "pickup" option in the controller mapping menu only seems to work on the main GUI, all "popup" windows like this "Visuals" one are not supported by the tool.
geposted 10 hours ago
It's the 2nd slider.
Great, that works:
deck master video_fx_slider 2
I struggled a bit because I wasn't seeing the "Transparency" fader moving on the parameter page, but it actually worked behing the scenes.
