Hi - when i load a new track on to deck thats playing there is a slight delay that puts track out of sync with playing track on opposite side anyone know the solution?
It does not happen when loading a track via the scratchbank or in serato.
All tracks have hotcues that are promted to play from the first cue.
This wasnt a problem using vdj with rane perfromer but is when using 2x rane 12s and djm s11. Is this a hardware problem? Im using a mac tahoe m2 high spec.
Thanks
Thanks
geposted 3 hours ago
