Load a song, then set a loop in the middle of it (or where you want...you could set a cue to remind later where it is)..
Then rewing the song using the vinyl disk without hitting stop (but you can use pause, but if you pause... then use the right click on the play button... it clears the loop), when it reaches that point... the loop will still be there
You can do the same with any effect !
Have you already known it ?
DJ Coco
DJ Coco
geposted Thu 12 Jun 03 @ 6:48 pm
lol of course but it is not working on the other side (with reverse tool for example)
geposted Fri 13 Jun 03 @ 4:32 pm
