Hey guys. I'm having less a problem than an annoyance. I checked the manual and Googled it but I can't find a fix that works. When I go to move tracks from one folder to another I get the dialogue box to do so, But the buttons on the bottom (Make New Folder,OK and Cancel are always obscured so I have to manually move the box. Not a MAJOR deal typically, but I'm completely reconfiguring a HUGE amount of files and it's getting annoying. I know someone is going to say do it from Windows Explorer, VDJ has them configured how I like it so its easier for me in VDJ. Picture included for context Any suggestions? Thank you in advance for any help.
BTW: I DID Google it and try to find it in the manual as well as posting on social media sites already. So now to the experts
geposted 11 hours ago
1) I don't know why your "Folder Select" dialog has this size, but that's not normal. Nor VirtualDJ stores and recalls the size of that window.
2) You can use SHIFT+DRAG to move a file between different folders directly from VirtualDJ browser.
3) You can use CTRL+DRAG to copy a file to a different folder, directly from VirtualDJ browser.
geposted 5 hours ago
