Topic: Browsing Music
My VDJ is intermittently not being able to find my music. It takes up to 2 minutes sometimes as its browsing my flies. None of the tabs (history, stems, itunes, other folders) will expand as its browsing. All of my music is internal. i only have 14,000 songs. This is concerning as i use this program for my business. I've uninstalled and reinstalled the program. I would understand if this were an Itunes issue alone but other files will not open as well.
I am running the most updated version of VDJ on a 2024 Macbook Pro M4 Max Chip Sequoia 15.7.3 with 36G of ram. I use this computer for DJing only. No heavy app usage accept for apple music.
I have a video of the problem I can share. Once the music finally loads functionality is perfect. I just takes an good amount of time to find the music most times. Sometimes it finds it instantly.. Sometimes it takes up to 2 minutes.
I have been using the program for close to 12 years without an issue. I consider myself a good troubleshooter. This one has me stumped. please advise!
geposted 5 hours ago
Can you check the tooltip of the 'Browsing' status message when it happens to see which folder it is stuck on exactly?
